U-Boot 2014.01 (Feb 13 2018 - 14:49:32) (OWEN-20180213-5522)
I2C: ready
DRAM: 128 MiB
NAND: 256 MiB
In: serial
Out: serial
Err: serial
ARM Clock : 400000000 Hz
DDR Clock : 150000000 Hz
Net: DaVinci-EMAC
owen: auth success
Hit any key to stop autoboot: 0
NAND read: device 0 offset 0xa0000, size 0x240000
2359296 bytes read: OK
## Booting kernel from Legacy Image at c0700000 ...
Image Name: Linux-3.4.15-rt25
Image Type: ARM Linux Kernel Image (uncompressed)
Data Size: 2332800 Bytes = 2.2 MiB
Load Address: c0008000
Entry Point: c0008000
Verifying Checksum ... OK
Loading Kernel Image ... OK
Starting kernel ...
Uncompressing Linux... done, booting the kernel.
[ 3.144850] mcp251x spi1.0: MCP251x didn't enter in conf mode after reset
[ 3.152282] mcp251x spi1.0: probe failed
[ 3.211484] pruss_uio pruss_uio: platform_get_irq_failed: -6
system release is 'OWEN-20180213-5522'
Mounting /dev...OK
Making device nodes...OK
Doing /etc/magic... restore is OK
plc type: PLC110-30K
loading system clock from stm32...ok
setting up /root/storage.vol as loop device...done
checking device /dev/loop0...ok
repairing /root/storage.vol if needed...done
usb_mstor: starting gadget...done
Setting up lo interface
Setting up hostname 'enlogic110'
set eth0 mac address to e4:1e:0a:01:c8:c7 (factory)
Setting up eth0 interafce
Setting static IP address 192.168.0.77 on eth0
Setting up usb0 interafce
Setting static IP address 10.0.6.10 on usb0
fw: creating chains
fw: adding default rules
fw: creating drop rules
Adding default gw 192.168.0.1
No need to update DNS
Starting dropbear sshd: OK
/root/retain/rmsync.cfg: correct
/dev/ttyS0: set as master
sh: write error: Device or resource busy
failed to export gpio9
prepare to start EnLogic system
starting enlogic system
connect to 192.168.0.78:7000 ..
enlogic110 login: connect to 192.168.0.78:7000 .. error (No route to host)
network.conf sz=68
LAN counts 1
ifconfig eth0 192.168.0.77 netmask 255.255.255.0
route add default gateway 192.168.0.1
enlogic: pthread_mutex_lock.c:87: __pthread_mutex_lock: Assertion `mutex->__data
.__owner == 0' failed.
