Показано с 1 по 10 из 108
Тема: Прошивка СПК207 - проблемы
    Ещё одна попытка. Обжал новый провод, снова кроссовый, на этот раз самый толстый и короткий. Взял другой debug провод. Установил винХР с нуля, с корп. Диска.
    Лог прошивщика:
    RomBOOT
    >RomBOOT
    CCC>
    Bootloader started
    Size of the whole device in bytes : 0x10000000
    Size in bytes of one single block of a device : 0x20000
    Number of blocks in the entire device : 0x800
    Size of the data area of a page in bytes : 0x800
    Number of pages in the entire device : 0x40
    Bus width : 0x8
    Nandflash initialized
    Enter Flash Address for Programming or press Enter for reset... 0x0
    Continue? Y / N
    Please transfer a binary file...
    CCC
    Binary file received. Size = 9216 bytes.
    Block #0 erased
    Block #0 programmed
    Binary file programmed...
    Enter Flash Address for Programming or press Enter for reset... 0x20000
    Continue? Y / N
    CCC
    Binary file received. Size = 254848 bytes.
    Block #1 erased
    Block #1 programmed
    Block #2 erased
    Block #2 programmed
    Enter Flash Address for Programming or press Enter for reset... 0xRomBOOT
    U-Boot 2010.03 (РћРєС‚ 15 2013 - 08:31:14) (OWEN-20131015-3302)
    CPU: AT91SAM9263
    Crystal frequency: 18.432 MHz
    CPU clock : 198.656 MHz
    Master clock : 99.328 MHz
    DRAM: 64 MB
    NAND: 256 MiB
    *** Warning - bad CRC or NAND, using default environment
    In: serial
    Out: serial
    Err: serial
    Net: macb0
    Hit any key to stop autoboot: 3 0
    U-Boot> setenv ethaddr 6A:77:00:22:00:4F
    U-Boot>
    U-Boot> setenv ipaddr 10.0.6.10
    U-Boot>
    U-Boot> setenv gatewayip 10.0.6.70
    U-Boot>
    U-Boot> setenv netmask 255.255.255.0
    U-Boot>
    U-Boot> setenv serverip 10.0.6.70
    U-Boot>
    U-Boot> setenv bootcmd 'nand read 22000000 A0000 360000;bootm 22000000'
    U-Boot>
    U-Boot> setenv bootargs 'mtdparts=atmel_nand:0x20000(bootstrap),0x80000(u-boot),0x360000(kernel),0x23C0000(rootfs),-(userfs) mem=64M root=ubi0:rfs rootfstype=ubifs ro console=ttyS0 ubi.mtd=4 ubi.mtd=5'
    U-Boot>
    U-Boot> setenv mtdparts 'mtdparts=atmel_nand:0x20000(bootstrap),0x80000(u-boot),0x360000(kernel),0x23C0000(rootfs),-(userfs)'
    U-Boot>
    U-Boot> setenv mtdids 'nand0=atmel_nand'
    U-Boot>
    U-Boot> saveenv
    Saving Environment to NAND...
    Erasing redundant Nand...
    Erasing at 0x80000 -- 100% complete.
    Writing to redundant Nand... done
    U-Boot>
    U-Boot> 3538944 bytes read: OK
    Wrong Image Format for bootm command
    ERROR: can't get kernel image!
    U-Boot> RomBOOT
    CPU: AT91SAM9263
    DRAM: 64 MB
    NAND: 256 MiB
    In: serial
    Out: serial
    Err: serial
    Net: macb0
    Hit any key to stop autoboot: 3 tumbler
    U-Boot> ping 10.0.6.70
    macb0: Starting autonegotiation...
    macb0: Autonegotiation complete
    macb0: link down (status: 0x7849)
    ping failed; host 10.0.6.70 is not alive
    U-Boot>
    macb0: link up, 100Mbps full-duplex (lpa: 0x4de1)
    Using macb0 device
    host 10.0.6.70 is alive
    U-Boot> nand erase a0000 360000; tftp 22000000 uImage.bin; nand write 22000000 a0000 140000
    NAND erase: device 0 offset 0xa0000, size 0x360000
    Erasing at 0xa0000 -- 3% complete.Erasing at 0xc0000 -- 7% complete.Erasing at 0xe0000 -- 11% complete.Erasing at 0x100000 -- 14% complete.Erasing at 0x120000 -- 18% complete.Erasing at 0x140000 -- 22% complete.Erasing at 0x160000 -- 25% complete.Erasing at 0x180000 -- 29% complete.Erasing at 0x1a0000 -- 33% complete.Erasing at 0x1c0000 -- 37% complete.Erasing at 0x1e0000 -- 40% complete.Erasing at 0x200000 -- 44% complete.Erasing at 0x220000 -- 48% complete.Erasing at 0x240000 -- 51% complete.Erasing at 0x260000 -- 55% complete.Erasing at 0x280000 -- 59% complete.Erasing at 0x2a0000 -- 62% complete.Erasing at 0x2c0000 -- 66% complete.Erasing at 0x2e0000 -- 70% complete.Erasing at 0x300000 -- 74% complete.Erasing at 0x320000 -- 77% complete.Erasing at 0x340000 -- 81% complete.Erasing at 0x360000 -- 85% complete.Erasing at 0x380000 -- 88% complete.Erasing at 0x3a0000 -- 92% complete.Erasing at 0x3c0000 -- 96% complete.Erasing at 0x3e0000 -- 100% complete.
    Using macb0 device
    TFTP from server 10.0.6.70; our IP address is 10.0.6.10
    Filename 'uImage.bin'.
    Load address: 0x22000000
    Loading: *################################################# ################
    done
    Bytes transferred = 1404148 (156cf4 hex)
    NAND write: device 0 offset 0xa0000, size 0x140000
    1310720 bytes written: OK
    U-Boot> nand erase 400000 23c0000; tftp 21c00000 plc.fs
    NAND erase: device 0 offset 0x400000, size 0x23c0000
    Erasing at 0x400000 -- 0% complete.Erasing at 0x440000 -- 1% complete.Erasing at 0x4a0000 -- 2% complete.Erasing at 0x500000 -- 3% complete.Erasing at 0x560000 -- 4% complete.Erasing at 0x5c0000 -- 5% complete.Erasing at 0x620000 -- 6% complete.Erasing at 0x680000 -- 7% complete.Erasing at 0x6c0000 -- 8% complete.Erasing at 0x720000 -- 9% complete.Erasing at 0x780000 -- 10% complete.Erasing at 0x7e0000 -- 11% complete.Erasing at 0x840000 -- 12% complete.Erasing at 0x8a0000 -- 13% complete.Erasing at 0x900000 -- 14% complete.Erasing at 0x940000 -- 15% complete.Erasing at 0x9a0000 -- 16% complete.Erasing at 0xa00000 -- 17% complete.Erasing at 0xa60000 -- 18% complete.Erasing at 0xac0000 -- 19% complete.Erasing at 0xb20000 -- 20% complete.Erasing at 0xb80000 -- 21% complete.Erasing at 0xbc0000 -- 22% complete.Erasing at 0xc20000 -- 23% complete.Erasing at 0xc80000 -- 24% complete.Erasing at 0xce0000 -- 25% complete.Erasing at 0xd40000 -- 26% complete.Erasing at 0xda0000 -- 27% complete.Erasing at 0xe00000 -- 28% complete.Erasing at 0xe40000 -- 29% complete.Erasing at 0xea0000 -- 30% complete.Erasing at 0xf00000 -- 31% complete.Erasing at 0xf60000 -- 32% complete.Erasing at 0xfc0000 -- 33% complete.Erasing at 0x1020000 -- 34% complete.Erasing at 0x1080000 -- 35% complete.Erasing at 0x10c0000 -- 36% complete.Erasing at 0x1120000 -- 37% complete.Erasing at 0x1180000 -- 38% complete.Erasing at 0x11e0000 -- 39% complete.Erasing at 0x1240000 -- 40% complete.Erasing at 0x12a0000 -- 41% complete.Erasing at 0x1300000 -- 42% complete.Erasing at 0x1340000 -- 43% complete.Erasing at 0x13a0000 -- 44% complete.Erasing at 0x1400000 -- 45% complete.Erasing at 0x1460000 -- 46% complete.Erasing at 0x14c0000 -- 47% complete.Erasing at 0x1520000 -- 48% complete.Erasing at 0x1580000 -- 49% complete.Erasing at 0x15c0000 -- 50% complete.Erasing at 0x1620000 -- 51% complete.Erasing at 0x1680000 -- 52% complete.Erasing at 0x16e0000 -- 53% complete.Erasing at 0x1740000 -- 54% complete.Erasing at 0x17a0000 -- 55% complete.Erasing at 0x1800000 -- 56% complete.Erasing at 0x1860000 -- 57% complete.Erasing at 0x18a0000 -- 58% complete.Erasing at 0x1900000 -- 59% complete.Erasing at 0x1960000 -- 60% complete.Erasing at 0x19c0000 -- 61% complete.Erasing at 0x1a20000 -- 62% complete.Erasing at 0x1a80000 -- 63% complete.Erasing at 0x1ae0000 -- 64% complete.Erasing at 0x1b20000 -- 65% complete.Erasing at 0x1b80000 -- 66% complete.Erasing at 0x1be0000 -- 67% complete.Erasing at 0x1c40000 -- 68% complete.Erasing at 0x1ca0000 -- 69% complete.Erasing at 0x1d00000 -- 70% complete.Erasing at 0x1d60000 -- 71% complete.Erasing at 0x1da0000 -- 72% complete.Erasing at 0x1e00000 -- 73% complete.Erasing at 0x1e60000 -- 74% complete.Erasing at 0x1ec0000 -- 75% complete.Erasing at 0x1f20000 -- 76% complete.Erasing at 0x1f80000 -- 77% complete.Erasing at 0x1fe0000 -- 78% complete.Erasing at 0x2020000 -- 79% complete.Erasing at 0x2080000 -- 80% complete.Erasing at 0x20e0000 -- 81% complete.Erasing at 0x2140000 -- 82% complete.Erasing at 0x21a0000 -- 83% complete.Erasing at 0x2200000 -- 84% complete.Erasing at 0x2260000 -- 85% complete.Erasing at 0x22a0000 -- 86% complete.Erasing at 0x2300000 -- 87% complete.Erasing at 0x2360000 -- 88% complete.Erasing at 0x23c0000 -- 89% complete.Erasing at 0x2420000 -- 90% complete.Erasing at 0x2480000 -- 91% complete.Erasing at 0x24e0000 -- 92% complete.Erasing at 0x2520000 -- 93% complete.Erasing at 0x2580000 -- 94% complete.Erasing at 0x25e0000 -- 95% complete.Erasing at 0x2640000 -- 96% complete.Erasing at 0x26a0000 -- 97% complete.Erasing at 0x2700000 -- 98% complete.Erasing at 0x2760000 -- 99% complete.Erasing at 0x27a0000 -- 100% complete.
    Using macb0 device
    Filename 'plc.fs'.
    Load address: 0x21c00000
    ################################################## ###RomBOOT
    CPU: AT91SAM9263
    DRAM: 64 MB
    NAND: 256 MiB
    In: serial
    Out: serial
    Err: serial
    Net: macb0
    2 1 0
    NAND read: device 0 offset 0xa0000, size 0x360000
    ## Booting kernel from Legacy Image at 22000000 ...
    Image Name: Linux-3.0.18-rt34
    Image Type: ARM Linux Kernel Image (uncompressed)
    Data Size: 1404084 Bytes = 1.3 MB
    Load Address: 20008000
    Entry Point: 20008000
    Verifying Checksum ... Bad Data CRC
    U-Boot>
    Видно, что файл недополучился и пошла циклическая перезагрузка.
    Лог tftpd:
    Connection received from 10.0.6.10 on port 1046 [31/10 13:04:02.173]
    Read request for file <uImage.bin>. Mode octet [31/10 13:04:02.207]
    OACK: <timeout=5,blksize=512,> [31/10 13:04:02.207]
    Using local port 1033 [31/10 13:04:02.207]
    <uImage.bin>: sent 2743 blks, 1404148 bytes in 2 s. 0 blk resent [31/10 13:04:04.371]
    Connection received from 10.0.6.10 on port 1050 [31/10 13:04:06.324]
    Read request for file <plc.fs>. Mode octet [31/10 13:04:06.358]
    OACK: <timeout=5,blksize=512,> [31/10 13:04:06.358]
    Using local port 1034 [31/10 13:04:06.358]
    TIMEOUT waiting for Ack block #5728 [31/10 13:04:53.490]
    Видно таймаут. Это, кстати, рекорд - 8% ещё ни разу не передавалось.
    UPD:
    Прошилось прошивкой v2.531.
    Но это никак не помогло в прошивке СПК 207-03.WEB v3.302
    UPD:
    Вероятно, битый файл СПК 207-03.WEB v3.302?
    Есть ли другая ссылка?
    Последний раз редактировалось Shayker; 31.10.2013 в 13:38.
  1. Прошивка ТРМ138
    от Stas в разделе Сервисное ПО
    Последнее сообщение: 09.10.2014, 12:58
  2. СПК207
    от kholonkin в разделе СПК2xx (архив)
    Ответов: 19
    Последнее сообщение: 28.08.2013, 22:11
  3. Прошивка ПЛК150ИМ.
    от _Александр_ в разделе ПЛК1хх
    Последнее сообщение: 06.09.2011, 17:48
  4. Прошивка 2-05-7
    от Дмитрий Артюховский в разделе ПЛК1хх
    Ответов: 13
    Последнее сообщение: 13.02.2009, 11:34
  5. МДВВ прошивка
    от igorsp в разделе Мх110
    Последнее сообщение: 27.10.2008, 19:27
