Показано с 1 по 10 из 19
Тема: System.ArgumentOutOfRangeException: Length cannot be less than zero. (Parameter 'leng
    По умолчанию System.ArgumentOutOfRangeException: Length cannot be less than zero. (Parameter 'leng
    При добавление комментария в ST возникает ошибка
    Она возникает если набрать (* и потом нажать enter.
    Ниже то что скопировалось в буфер ошибки
    2.6.348.0
    System.ArgumentOutOfRangeException: Length cannot be less than zero. (Parameter 'length')
    at System.String.Substring(Int32 startIndex, Int32 length)
    at StParser.Lexer.CreateMultilineCommentToken(String input, TokenPosition& tokenPosition)
    at StParser.Lexer.AnalyzeInput(String input, CancellationToken cancellationToken)
    at Owen.STEditor.Editor.STIndentationStrategy.IndentL ine(TextDocument document, DocumentLine line)
    at ICSharpCode.AvalonEdit.Editing.TextArea.ReplaceSel ectionWithNewLine()
    at ICSharpCode.AvalonEdit.Editing.TextArea.PerformTex tInput(TextCompositionEventArgs e)
    at ICSharpCode.AvalonEdit.Editing.EditingCommandHandl er.OnEnter(Object target, ExecutedRoutedEventArgs args)
    at System.Windows.Input.CommandBinding.OnExecuted(Obj ect sender, ExecutedRoutedEventArgs e)
    at System.Windows.Input.CommandManager.FindCommandBin ding(CommandBindingCollection commandBindings, Object sender, RoutedEventArgs e, ICommand command, Boolean execute)
    at System.Windows.Input.CommandManager.FindCommandBin ding(Object sender, RoutedEventArgs e, ICommand command, Boolean execute)
    at System.Windows.Input.CommandManager.OnExecuted(Obj ect sender, ExecutedRoutedEventArgs e)
    at System.Windows.RoutedEventArgs.InvokeHandler(Deleg ate handler, Object target)
    at System.Windows.EventRoute.InvokeHandlersImpl(Objec t source, RoutedEventArgs args, Boolean reRaised)
    at System.Windows.UIElement.RaiseEventImpl(Dependency Object sender, RoutedEventArgs args)
    at System.Windows.UIElement.RaiseTrustedEvent(RoutedE ventArgs args)
    at System.Windows.Input.RoutedCommand.ExecuteImpl(Obj ect parameter, IInputElement target, Boolean userInitiated)
    at System.Windows.Input.CommandManager.TranslateInput (IInputElement targetElement, InputEventArgs inputEventArgs)
    at System.Windows.UIElement.OnKeyDownThunk(Object sender, KeyEventArgs e)
    at System.Windows.Input.InputManager.ProcessStagingAr ea()
    at System.Windows.Input.InputProviderSite.ReportInput (InputReport inputReport)
    at System.Windows.Interop.HwndKeyboardInputProvider.P rocessKeyAction(MSG& msg, Boolean& handled)
    at System.Windows.Interop.HwndSource.CriticalTranslat eAccelerator(MSG& msg, ModifierKeys modifiers)
    at System.Windows.Forms.Integration.ElementHost.Proce ssCmdKey(Message& msg, Keys keyData)
    at System.Windows.Forms.Control.PreProcessMessage(Mes sage& msg)
    at System.Windows.Forms.Control.PreProcessControlMess ageInternal(Control target, Message& msg)
    at System.Windows.Forms.Application.ThreadContext.Pre TranslateMessage(MSG& msg)
    2.6.348.0
    Правильно появляется, при чём на других версиях тоже. Вы не закрыли комментарий набрав *) и нажали Ввод, поэтому и ошибка.
    Даже в Codesys 2.3, если открыть комментарий (* и не закрыть, будет ошибка при компиляции.
    Последний раз редактировалось kondor3000; 29.04.2024 в 19:22.
    Нет, обождите...
    Это же многострочный комментарий, и он закрыт в последней строке.
    Возможно программисты не предусмотрели чтоб (* стоял в пустой строке...
    10,693
    комментарий не может быть длиной 0.
    з.ы. такая ошибка должна обрабатываться программой и выдавать соответствующее предупреждение и методы решения, а не валить Исключением.
    вероятно после (* надо писать текст начинать.
    10,254
    просто интересно, а кроме окна с предупреждением о нулевой длине, кто то видит ошибку в соответствующем поле, ведь не зря же ТС привел вырезку только окна кода, без окна ошибок
    Ну мы доверяем ТС, он вроде указал причину. Нам что броситься смотреть код...
    10,254
    ну собственно чтоб вести дискуссию по теме, да, надо перепроверять, чтоб самому убедиться и делать соответствующие выводы, а эти вероятно, возможно, вроде не дают понимания что делать дальше вопрошающему с оппонентами. Проблема тут обычная, это в Substring один из аргументов равен -1, а не пустая строка после (*
    Так у вас там пробелы, вы попробуйте сразу после (*...
    10,254
    я конечно же в курсе
    У меня телефон. Пришлось после ваших сообщений идти на рабочий комп по удаленке. Да, я проверил после ваших сообщений. Какой смысл мне не доверять ТС, если он написал, что всплывающее окно сообщения об ошибке появляется послеинажатия ввода после (*.
    Сразу предположил, ошибка среды, которая не допускает отсутствие символов после (*.
    А вы ввели пробелов и на те, ТС врёт. Это вы реализовали не эту ситуацию.
  1. System.NullReferenceException
    от majevgenij в разделе Среда программирования OWEN Logic
    Последнее сообщение: 14.06.2018, 10:22
  2. TPM202, Modbus, C#, System.TimeoutException
    от Tiruno в разделе Помощь Разработчикам
    Последнее сообщение: 18.03.2016, 17:38
  3. Сбор данных с приборов OWEN через System.IO.Ports.SerialPort
    от iKarma в разделе Помощь Разработчикам
    Последнее сообщение: 28.03.2015, 16:34
  4. СПК1xx System Events
    от pqqp в разделе СПК1хх
    Последнее сообщение: 27.10.2014, 11:13
