Страница 46 из 55 ПерваяПервая ... 364445464748 ... ПоследняяПоследняя
Показано с 451 по 460 из 545
Тема: ПЛК110 М02 MasterSCADA 4D
  1. #451
    Убрал работу с выходами МЭ
    осталось следующее:
    14 BC 43 7D
    80029158:res=12 err=115 Task=12 iTimeout=1000 len=12: 01 EF 00 00 00 06 01 03 14 84 00 06  -> (task=12 dt=3 c=21(21)) 01 EF 00 00 00 0F 01 03 0C 00 00 00 00 00 00 00 00 00 00 00 00
    80029176:res=12 err=115 Task=12 iTimeout=1000 len=12: 01 F0 00 00 00 06 01 03 14 C0 00 06  -> (task=12 dt=6 c=21(21)) 01 F0 00 00 00 0F 01 03 0C 96 C9 43 69 E7 6D 43 75 64 DD 43 70
    80029199:res=12 err=115 Task=12 iTimeout=1000 len=12: 01 F1 00 00 00 06 01 03 14 CC 00 06  -> (task=12 dt=13 c=21(21)) 01 F1 00 00 00 0F 01 03 0C 51 AA 43 D2 22 D1 43 D0 03 12 43 D0
    80029230:res=12 err=115 Task=12 iTimeout=1000 len=12: 01 F2 00 00 00 06 01 03 14 D8 00 02  -> (task=12 dt=13 c=13(13)) 01 F2 00 00 00 07 01 03 04 F0 A4 42 47
    80029252:res=12 err=115 Task=12 iTimeout=1000 len=12: 01 F3 00 00 00 06 01 04 00 33 00 01  -> (task=12 dt=5 c=11(11)) 01 F3 00 00 00 05 01 04 02 00 00
    0ModbusTCP readex 192.168.254.173
    80029268:res=12 err=115 Task=12 iTimeout=1000 len=12: 00 A6 00 00 00 06 01 03 0F A0 00 02  -> (task=12 dt=5 c=13(13)) 00 A6 00 00 00 07 01 03 04 FE BC 40 A6
    80029284:res=12 err=115 Task=12 iTimeout=1000 len=12: 00 A7 00 00 00 06 01 03 0F E0 00 01  -> (task=12 dt=4 c=11(11)) 00 A7 00 00 00 05 01 03 02 00 34
    0ModbusTCP readex 192.168.254.174
    80029304:res=12 err=115 Task=12 iTimeout=1000 len=12: 00 F9 00 00 00 06 01 03 00 33 00 01  -> (task=12 dt=9 c=11(11)) 00 F9 00 00 00 05 01 03 02 00 00
    0ModbusTCP readex 192.168.254.245
    80029331:res=12 err=115 Task=12 iTimeout=1000 len=12: 00 54 00 00 00 06 01 02 00 00 00 08  -> (task=12 dt=12 c=10(10)) 00 54 00 00 00 04 01 02 01 18
    0ModbusTCP write 192.168.254.171
    0ModbusTCP write 192.168.254.173
    0ModbusTCP write 192.168.254.174
    80029385:res=17 err=115 Task=12 iTimeout=1000 len=17: 00 FA 00 00 00 0B 01 10 01 D6 00 02 04 00 00 42 C2 888660984 [2020-12-05T22:13:49.000Z] |-1458436992|:In file opcua_p_socket.c at line 1418: <-- "P_Select" = 0x00000001 (GOOD).
    И всеравно не пишет в .174 ничего (((
    Хотя как я понимаю мы как раз щас правильно пишем в нужный адрес, нужное количество и тп. или я не прав?
    ну судя по Вашему разбору строки - тут по сути то же самое.... только пишем не 00 00 00 00, а 00 00 42 С2
    в настройках модуля стоит:
    последовательность байт _1_0_3_2 (в вещ и целых)
    в 8 байт стоит _1_0_3_2_5_4_7_6
    я дурак: столько дней бегал, а у меня тип данных на выходе стоял "вещественный" сменил на "беззнаковый целый" - заработало...
    пойду побеждать выходы МЭ и работу с выходами Лого!
    Последний раз редактировалось Evgeny.Syromyatnikov; 06.12.2020 в 01:29.
  2. #452
    Цитата Сообщение от Трофимов Артем Посмотреть сообщение
    Здравствуйте, Уважаемые форумчане.
    Мы с радостью сообщаем об открытии продаж контроллеров ПЛК110 М02 в исполнении MasterSCADA 4D.
    Попробовал сделать небольшой проект на этом контроллере.
    От общения с MasterSCADA 4D радость пропала.
  3. #453
    Велкам, в Новый год.
    Не обновляйтесь
    Словил подарок из инсата:
    Нынешняя версия 1.2.11.20657 из обновления от 21 декабря
    После обновления исполнительной системы и загрузки конфигурации : контроллер становится недоступен
    Логи щас выгружу и добавлю сюда
    Последний раз редактировалось Федор Назаров; 23.12.2020 в 13:55. Причина: нарушение п.5.4 правил форума
  4. #454
    Не выложу логи. Их нет. В папке /root/mplc4 какие бы то ни было логи - отсутствуют.
  5. #455
    Мой косяк предновогодний, совпало обновление и отключение внешних модулей, по в итоге выловился косячный бесконечный цикл в программе. исключил нафиг.
    Спасибо техподу инсата...
  6. #456
    10.11.2014
    Санкт-Петербург
    995
    Радует, что отписались...
    А то у нас принято свои косяки на других списывать...
  7. #457
    Не, я свои косяки предпочитаю признавать и озвучивать, позволяет не допускать подобных косяков ни мне, ни коллегам...
  8. #458
    08.01.2021
    Лабинск
    6
    Добрый день. Скажите как работает ПЛК с данной системой на сегодняшний день и стоит ли её брать для управления домашнего освещения (через планшет и физ. кнопки)?
  9. #459
    Чисто технически декабрьская версия - работает, даже все предыдущие косяки по коннектам и связям параметров внутри - починили.
    Немного непривычный язык, но это решабельный вопрос.
    про свет не скажу, у меня оно управляет водоснабжением и водоотведением, а так же климатом нескольких помещений в которых зимой надо бы подогревать (кессон скважины, насосная, генераторная). еще не пробовал HMI экраны, но наверное придется попробовать
    ЗЫ: причем в тестовом режиме он у меня спокойно забирает значения входов с Siemens !LOGO по Ethernet. и теоретически (так и не придумал зачем) может тянуть данные из S7-1200/1500.
    Последний раз редактировалось Evgeny.Syromyatnikov; 17.01.2021 в 00:22.
  10. #460
    08.01.2021
    Лабинск
    6
    Спасибо! Я как рас и хотел понять стабильность работы. А то на форуме много негатива про МСК4Д, а брать чистый ПЛК110 на CDS2 и городить еще ОПС в доме еще и на windows не очень хочется!
  1. ПЛК110 со средой исполнения MasterSCADA 4D
    от Kirill в разделе ПЛК (среда MasterSCADA 4D)
    Ответов: 31
    Последнее сообщение: 06.05.2021, 14:21
  2. Ответов: 25
    Последнее сообщение: 30.07.2015, 14:53
  3. конвертация проекта из Masterscada 3.5 в Masterscada 3.4
    Последнее сообщение: 01.04.2013, 17:56
  4. Ответов: 4
    Последнее сообщение: 23.04.2012, 13:56
